help
Old 06-29-2012, 04:30 PM
dragonmaster093
Default help
ok on my wagon it has a lil 3.8 with the dual jet ( 1/2 a quadra jet) what other 2 barrel vard will bolt up? this thing is a pos on its last leg and dont wanna rebuild it cause to put and aftermarket air cleaner i have to have a hard to find special adapter. any help would be helpful
dragonmaster093 is offline
Old 06-30-2012, 06:04 AM
I've used the 4412 Holley 500CFM 2bbl in a variety of applications for years. EZ to tune a set up. Standard size aircleaner base and same jets as 4bbl Holleys.
Old 06-30-2012, 02:12 PM
dragonmaster093
are the bolt paterns the same?
Old 06-30-2012, 03:14 PM
Sorry, I can't answer that as I do not know. Someone on here will know, tho.
Old 06-30-2012, 04:41 PM
dragonmaster093
ok thanks DD
Old 06-30-2012, 06:05 PM
fast75vega
i know i seen lil imports with 4 cyl motors with 4barrel 600cfm and bigger carbs ....lol they have adapter plates for almost everything now
fast75vega is offline
Old 06-30-2012, 07:11 PM
dragonmaster093
lol fast but in my opinion 600 cfm 4 barrel would be way too much over kill for a stock 3.8 heck 500 cfm probably too big figure a lil 350 cfm should work but need to know if itll bolt up. can get get a remaned dual jet for like 200 buti would be back to searching for an adapter.
Old 06-30-2012, 09:13 PM
Check this place out; scroll down the home page and see what they've got within the website;
http://www.carburetion.com/index.htm
More here;
http://www.carburetorsandmore.com/
And adapters here with measurements;
http://www.summitracing.com/search/?...=carb+adapters
