regulator
Old 02-24-2010, 02:39 PM
spib
Default regulator
I was told by a company that I just got a regulator from to not mount regulator, just plumb in line, up close to carb
he said vibrations when you mount a regulator will kill them
agree or disagree ?
my set up is single carb, 8an line 600 hp motor, no return line
spib is offline
Old 02-24-2010, 04:08 PM
gnsrule
I mounted mine on the old car and never had a problem. Im trying to find a good spot right now to mount it on the new car but havent found the right spot yet.
Whos regulator did you get? If its a BG 4 port, place a lock washer under the mounting bracket bolts if you use it as the supplied bolts are too long and doesnt squish the diaphram down tight. It will leak. I speak from experiance on this one. I called BG last time and they told me they never seen that before and now 4 years later I buy a new one and see the same thing.
Craig
gnsrule is offline
Old 02-24-2010, 04:13 PM
spib
Its a moddified holley I believe from pro systems carb, looks like my small reg I got with my blue pump but it uses 1/2 inch in and out
http://www.prosystemsracing.com/cata...92/5339867.htm
spib is offline
Old 02-24-2010, 06:37 PM
mopar1968
mopar1968's Avatar
Mine is mounted on the firewall, with line to carb, no problems :!: :!:
''JUST MY TWO CENT'S WORTH''
mopar1968 is offline
Old 02-24-2010, 07:55 PM
Mine is mounted on the passenger fenderwell, when running gas with 2 #6 lines going too the carb. I have a duel setup with a 10 gal tank in the trunk and a 3 gal. for alcohol mounted left front for the injection.
Old 02-24-2010, 11:38 PM
gnsrule
[quote="mopar1968"]Mine is mounted on the firewall, with line to carb, no problems :!: :!:
I belive NHRA sais no fuel line can be within 2 inches of the firewall, for what its worth.
Craig
gnsrule is offline
Old 02-25-2010, 10:30 AM
spib
[quote="gnsrule"][quote="mopar1968"]Mine is mounted on the firewall, with line to carb, no problems :!: :!:
Craig[/quote
6" I believe for regulator, they get that I believe with the fact it states must be 6" forward of flywheel, bell housing area
spib is offline
Old 02-25-2010, 07:47 PM
mopar1968
mopar1968's Avatar
If you look at the pics in my profile you will see it mounted in passenger side of firewall, goes thru tech at every race, we race NHRA Track.
http://www.racingjunk.com/gallery/profile/163312/181736
Old 02-26-2010, 07:00 AM
al34
:wink: That is correct I got hit in tech 2 years ago for having the reg on the fire wall and had to relocate it.
al34 is offline
Old 02-26-2010, 07:09 AM
spib
mark I used to have mine just like yours, first race they made me move it, some tracks are just not that picky
spib is offline
