th 350 problems
Old 01-02-2010, 11:13 AM
SkylerFaoro
Default th 350 problems
I have a th 350 and finished install last night drove great went to drive today goes into gear but only moves at higher rpm could this be a bad oil pump? any advice is great thanks.
SkylerFaoro is offline
Old 01-02-2010, 12:38 PM
kwkracing
Are you sure the convertor was all the way in the tranny when you installed last nite? Did it function properly then? Is it stock?
kwkracing is offline
Old 01-02-2010, 02:27 PM
Dump in enough Trany Fluid ?
Old 01-03-2010, 04:06 PM
SkylerFaoro
Yes converter is all the way in and yes it is bolted. yes it worked perfict than didnt work. yes stock converter. and yes plenty of fluid
