Alch jetting on 850 Quick Fuel help
Old 10-09-2009, 03:01 PM
bajaboat32
Default Alch jetting on 850 Quick Fuel help
I neeed some help on a starting point for jetting.
2600 lbs door car
468 bbc
12.5:1
Oval port heads
Mild cam
Single plane
176 Glide
488 Gear
850 Quick Fuel Carb
Thanks
bajaboat32 is offline
Old 10-09-2009, 07:42 PM
Old 10-10-2009, 05:59 AM
bajaboat32
Thanks, I will start there.
Old 10-10-2009, 06:45 AM
Them carbs can be a bit tricky to get right, do you have a egt or just going to tune by #'s on et slip ?
Old 10-12-2009, 04:28 PM
degnitz_3732
I have a 468 BBC in a dragster. I have a Quick Fuel 950A carb that came with 160s. I ended up with 168 all around, and messed more with the air and idle mixture. Did you ever say if yours was gas or methanol?
degnitz_3732 is offline
Old 10-12-2009, 07:09 PM
Says alky in topic heading :lol:
