What size slicks?
Old 05-09-2009, 10:57 AM
ssym
Default What size slicks?
I have a '66 Chevy II, tubbed in the rear with a 4-link. 3200 Pounds.
Blown SBC, 630 HP, 605 TQ, TH-400
I have a set of 15" x 15" rims. Plenty of room to run 33"x16"s.
Question is, How wide is wide enough? Should I run 14's, 14.5's, 15's? I see people hooking with 10.5's with much more power. I would like to save money and use the rims I have, but how much is overboard?
Is height any more a question than roll out and gear ratio?
I assume D-5 compound or equivelent.
Thanks again. Should have track pics within a month. Long time comin!
Steve
ssym is offline
Old 05-09-2009, 05:35 PM
us7race
a 32x14 should do you just fine. What rear gear?
us7race is offline
Old 05-10-2009, 08:42 AM
ssym
3.50's right now. Waiting to see the first 1/4 mile results before I change them.
Steve
ssym is offline
Old 05-10-2009, 01:18 PM
dparker
Default Re: What size slicks?
Steve
14x32's would work, but you mentioned that you wanted to run 15x15 rims. So your probably going to have to run a 16x33. Your tire needs to be an inch wider than your rim width.
dparker is offline
Old 05-11-2009, 02:17 AM
ssym
Any thoughts on the Hoosier Quick TIme Pro DOT tires? They make the same size as my street tires(31-18-15), just curious if they will hook on the track.
ssym is offline
Old 05-11-2009, 05:30 AM
oldandtired
oldandtired's Avatar
Steve
3.50's ??? Not a good starting point with a 33 tire. Just my opinion. Dave
oldandtired is offline
Old 05-11-2009, 05:41 AM
blowninjected540
Steve
x2 456 or even 488 would be my guess with a 33 inch tall tire
blowninjected540 is offline
Old 05-11-2009, 05:43 AM
johnracer
Steve
Agreed. 3.50's are a waste of time. At 3200 lbs, you'll need a 5.13 or better with a 33" tire........my Vette with a 575-600hp sbc @2050lbs and a 4.88 gear turned about 7000 rpm at the stripe and 7700 on nitrous with a 33x16
johnracer is offline
Old 05-11-2009, 06:32 AM
dparker
They will not hook like a set of slicks. Unless I was running a class that demanded DOT tires, I would run slicks at the track.
dparker is offline
Old 05-11-2009, 10:56 AM
ssym
Thanks guys. I had 4:86's with a spool and put the 3:50's with a locker in for the street. Now I miss the track and plan on building a second third member with the spool and I don't know what gears. I redline at 6300 rpm and thought 4:86 might be a little steep for the 1/4 mile.
Still not decided on what size slicks to run...
I'll have money next week for them and the track soon after!
Steve
ssym is offline
