chevy 355 horsepower?
Old 03-12-2009, 03:17 PM
eagle355
Default chevy 355 horsepower?
I'm building a 355 chevy for a 84 4x4 truck but i want it to run really good but it's the first engine ive ever built I will list my parts and you estimate the hp and offer any help i'm willing to take advise thanks.
bottom end
it's a 1990 2 bolt main block
it's 30 over new freeze plugs cam bearings
eagle cast steel crank
eagle sir i beam rods
keith black flat top silverlite pistons and hasting rings
top end
procomp aluminum heads 202\160 200 cc 64cc chamber
crane cam and lifters 278 450 lift
roller rockers
holley intake and carb
i'm sure i'm forgetting something but thanks
eagle355 is offline
Old 03-12-2009, 07:18 PM
radicalz
Good to see you are building something....but why not throw a strokedr crank in it and make it a fire breathing 383 or more......might just like that truck then......est on your combo poss 400-450hp....change the cam and throw a stroker crank in it est up to 600-650hp that will break the tires loose
radicalz is offline
Old 03-12-2009, 07:36 PM
Everything sounded good till you said the procomp word :shock:
Old 03-12-2009, 08:32 PM
eagle355
what would you recommend this is going in a truck i drive every day to work that's got a stock 305 in it now
eagle355 is offline
Old 03-13-2009, 03:42 AM
radicalz
My question is what do you want to do with the truck.....cruise, race, mud bogs, off roading....I would go with a better head like AFR's of some Darts may be more expensive now but well worth the investment and bump the cam up more lift and duration.....or you could go with a crate engine from GM that ZZ4 350....good engine...good hp....but the other thing that 4X4's like is torque....they also make a 383....which is a stroked out 350
radicalz is offline
Old 03-13-2009, 04:41 AM
eagle355
all around great drivability and durability but around 400-450 horsepower
eagle355 is offline
Old 03-13-2009, 07:53 AM
desoto30
do you have the listed parts or are they the ones that you are considering?
desoto30 is offline
Old 03-13-2009, 08:15 AM
twobad1
cheap,reliable,strong ...you can only have 2 you pick
twobad1 is offline
Old 03-13-2009, 12:18 PM
radicalz
I've got a 92 chevy pu 4X4 that is cheap, dependable, and has great durablity....and the 350 in it is only about 200hp with 200,000 miles....not to blow your candles out...I say the best bang for your buck would be to check out some crate engines....plug and play with a warranty :wink: :wink: :wink: check out GM Performance, Scoggin-Dickey Chevrolet, Stroker Engine.com, Speed O Motive, PAW Warehouse....I would also be leaning to a stroker engine....best bang for the buck.....Big Blocks work well in those trucks too!!!!
radicalz is offline
Old 03-13-2009, 01:37 PM
TopspeedLowet
I got an idea to get that 450 HP figure and be durable and cheap. build it with the parts you have. Then get a NO2 system with a 250 HP plate at a swap meet. Then you can have the 450 HP reliable and cheap. JUST NEVER USE THE NO2, EVER. :wink:
The crate engine idea is a good one, that will let you get assembly experience without the trouble of getting machine work checked and get a warranty. You can always add on later to the combination.
Bruce
TopspeedLowet is offline
