SCAT PRODUCTS OR NOT
Old 02-04-2009, 07:56 PM
fsdragster
Default SCAT PRODUCTS OR NOT
LOOKING TO PURCHASE A BBC STROKER MOTOR FOR 90% STREET USE AND JUST WONDERING IF PURCHASING ONE WITH SCAT INTERNALS IS THE WAY TO GO. SEVERAL OF THE WELL KNOWN ENGINE COMPANYS APPEAR TO BE USING MORE OF THERE CRANKS THAN THEIR RODS OR PISTONS AND OF COURSE THERE PRICES REFLECT THIS. HEARD ALOT ABOUT EAGLE BOTTOM ENDS BUT WAS TOLD THAT SOME ASSEMBLIES COME FROM OVERSEAS COMPANYS AND ARE TOTAL JUNK. I AM ONLY ASKING SO I GET IT RIGHT THE FIRST TIME. ALSO WHAT ABOUT THESE 2 YEAR WARRANTIES THAT SOME OF THE WELL KNOWN BUILDERS OFFER. THANKS FRANK
fsdragster is offline
Old 02-04-2009, 09:57 PM
Both Scat and Eagle are forged over seas and machined here in the states.
Scat has been on the scene along time, used to run that stuff in my VW.
I have forged Eagle internals in my BBC - everything was good, right out the box.
I don't think you'd go wrong with either, so long as you double check everything real good before assembly and get a good spin job.
Goodluck, Cp
Old 02-05-2009, 01:14 AM
BEAST477
BEAST477's Avatar
Yes make sure you have them checked. Got two Eagles, one was bad enough it would have to go.010- .010 right out of the box and the other was .010 off on the stroke. So i went with a Callies Compstar. About $150.00 more. Areally nice piece. Just something to think about.
BEAST477 is offline
Old 02-05-2009, 04:55 AM
slowmotion
I bought my engine fo my altered from http://www.high-performance-engines.com/index.shtml No problems with it. It's basically a street car engine. It also comes with a 2 year warranty.
slowmotion is offline
Old 02-05-2009, 05:01 PM
tcarda
I have Eagle 4340 crank and rods in my 540 with no problems. Also, my 469 had Eagle 4340 crank and rods with no failures either. One of my friends bought a cheap $150 Eagle and had a lot of problems with that. Spend the extra money and buy the higher quality crank and rods.
tcarda is offline
Old 02-05-2009, 06:56 PM
fsdragster
SERIOUSLY LOOKING AT THE SUNSET RACECRAFT 565 PUMP GAS. SEEMS TO BE ASSEMBLED WITH GOOD PARTS.
Old 02-19-2009, 04:54 PM
danrich
Just bought a Reher Morrison 565 with the 18 degree Big Chief top end - a nice 1000 HP piece - and the only crank R-M will sell for the combo is a Scat so they must be reputable/dependable.
danrich is offline
Old 02-19-2009, 05:26 PM
i ran a 383ci (671 Big Bore) Alcohol,blown,injected car (1100 hp @15lbs boost) with a Scat Crank,Crower Rods,SRP Pistons. (65 Nova)
My 572ci 1471 Alcohol Blown Injected 23T altered was 1600hp at 20lbs of boost with the Good Eagle Crank,GRP rods and JE Psitons..
see pics Below..Yes thats Me with the Nova.... ..so Now you think your street engine will be ok...lol
[img][/img]
[img][/img]
[img][/img]
Old 02-19-2009, 06:44 PM
bubbabbc
Default Quality cranks and rods
I've been using Compstar from Callies in Fostoria, Ohio. Best for the money, IMO.
bubbabbc is offline
Old 02-19-2009, 07:00 PM
Default Re: Quality cranks and rods
in my new 565ci i have callies stealth crank and callies compstar rods.diamond pistons
