Enderle Tunnel Ram Injection
Old 07-18-2008, 05:36 AM
mudder81
Default Enderle Tunnel Ram Injection
I have a Enderle Birdcatcher on a tunnel ram that I bought used and I have a question about it. Looking over tech sheets from Good Vibes Racing for it, I have an extra check valve(by-pass maybe?) that is not the tech sheet. Fuel goes through the pump and then through the 3-way shut-off. Thats good. Heres where it gets funny, there is a tee with a check valve on it, on the end of the 3-way, so the fuel can go through the check valve or up to the barrel valve. What is this for? Thanks for your help.
Just got word, its a high-speed lean out.
mudder81 is offline
Old 07-19-2008, 03:17 AM
demented
Its called a "pump sizer". It is used if the pump is too big for the system. It allows fuel to be sent back to the tank and regulate how much goes to the barrel valve. You don't see too many of these because its more of a bandaid fix for a system that was piece mealed together. The best thing you could do is to send your system out to someone like Koehler injection and have the system flowed for your motor. Makes a world of difference and is worth every penny(Costs around $450.00)
demented is offline
Old 07-28-2008, 05:24 AM
mudder81
OK, got that figured out, now which spark plugs do I need to run(type,heat, etc.)?
mudder81 is offline
Old 07-28-2008, 04:43 PM
demented
Need some info about the motor.
demented is offline
Old 07-29-2008, 04:06 AM
mudder81
434 SBC, 12:1 comp., bowtie alum heads(ported and polished), .7?? lift solid roller cam(sorry dont have the specs on hand), 1.5 roller rockers. Anything else? Thanks
mudder81 is offline
Old 07-30-2008, 04:15 PM
demented
Are you running any nitrous?
demented is offline
Old 07-31-2008, 12:13 PM
mudder81
Nope, not yet.
mudder81 is offline
Old 07-31-2008, 06:00 PM
demented
Just one observation, 12:1 comp is a little low for alcohol in my opinion . It may not live up to expectations with that low of compression and a cam in the .7's of lift . Anyways start with a heat range that is in the middle and check your plugs from there. Alcohol is pretty forgiving on tunes but you still have to optimize it to get the most power.
demented is offline
Old 08-01-2008, 07:26 AM
mudder81
What brand of alcohol do you use? I was leaning towards VP's M5 but it might be more than what I want to spend, so M3 may have to do.
mudder81 is offline
Old 08-01-2008, 04:47 PM
demented
I use powermist holeshot methanol. I have never used the VP methanol but I hear that the M5 won't pass a fuel test if you ever got tested. Some of the races I go to test for nitro so I gotta have fuel that will pass.
demented is offline
