re; hilborn stack injection & methanol
Old 04-15-2008, 07:09 PM
suicidebomb
Default re; hilborn stack injection & methanol
I need help
suicidebomb is offline
Old 04-15-2008, 07:54 PM
OneBadGMC
http://racecarbook.com/
Buy the Injection Secrets book!!! It's WELL worth the money!!!
What help do you need?
OneBadGMC is offline
Old 04-15-2008, 09:25 PM
suicidebomb
I already have Mr. Szabo's books on fuel injection,
Old 04-16-2008, 06:53 AM
bbchevy
Default Injection?
I would say if it was Fine last season?And,now its Not???Well then you have some Issues with Junk in the Fuel System?Have you COMPLETELY pulled the WHOLE System apart and Cleaned everything?That would be where i would Start?
Then,how about the Pump,what condition is it in?
Lastly,maybe check you Throttle blades for adjustment?
HOPE THIS HELPS?
Later
G 8)
bbchevy is offline
Old 04-16-2008, 07:21 AM
suicidebomb
I"m in the process of cleaning every part and piece now.
Old 04-16-2008, 07:54 AM
OneBadGMC
Can you help me help you?
I need the pump GPM, nozzle sizes, main bypass pill size, poppet pressures on main & secondary.
Is it a Hilborn or Enderle barrel valve?
Old 04-16-2008, 09:53 AM
suicidebomb
It has a hilborn barrel valve
Old 04-16-2008, 10:12 AM
OneBadGMC
What's the pump GPM @ 4000 Pump RPM?
Do you have flow at the industry standard 100 PSI?
Old 04-16-2008, 11:05 AM
suicidebomb
My engine is running out of gas
Old 04-16-2008, 12:06 PM
OneBadGMC
You have a PM.
