engine bearings SBC
Old 04-04-2008, 02:30 PM
dgordner
Default engine bearings SBC
Would someone tell me the difference between the Clevite MS909P Main bearing and the MB2508P Main Bearing.
dgordner is offline
Old 04-04-2008, 03:06 PM
jmarksdragster
jmarksdragster's Avatar
The MS909P is a standard LJ350 main bearing. The MB2508 appears to have a .020 reduced width on the rear main, probably for a block that spun a rear main and required repair.
jmarksdragster is offline
Old 04-04-2008, 03:23 PM
dgordner
Thank you very much. I quess it would be smart to replace it with what I took out correct?
dgordner is offline
Old 04-04-2008, 03:32 PM
I would...unless of coarse what you took out wasn't working.
Old 04-04-2008, 04:10 PM
jmarksdragster
This site gives you measurements for that bearing. Measure your block and old bearing.
http://www.enginetechcatalog.com/Int...Set%20-%20Main
Old 04-04-2008, 05:22 PM
dgordner
Thank You !![/b]
dgordner is offline
