Ground Wire Size
Old 06-13-2007, 06:09 PM
robinhorn
Default Ground Wire Size
I am looking to mount a ground block for all my ground wires that has a line that runs to the battery. What I need to know is what size whould the wire be that goes to the battery from the trunk. Also what size wire should I use for ground wires.
Thanks
robinhorn is offline
Old 06-14-2007, 01:15 AM
topsportsman1
I personally use a #10 wire from the battery in the trunk to a ground block up in the front of the car.I use this for a few direct grounds,for the nitrous system,only to keep other grounds such as ignition,water pump and fuel pump,which are grounded to the chassis
topsportsman1 is offline
Old 06-14-2007, 03:32 AM
curtisreed
curtisreed's Avatar
Robinhorn,
Here is some useful info from Shogun.
https://www.shogunindustries.com/cgi...ch/ground.html
curtisreed is offline
