what is a reasonable reliable rpm for 572 4.5 by 4.5
on a 572 bbc in a boat, what would be the top rpm to turn the motor to keep it reliable? It has 6.535 length rods and 4.5 stroke and 10.2 deck. I really need to add a little nitrous to get a little more power and need to turn 7000 rpm. Will the low rod stroke ratio take its toll at this rpm. This rpm is only obtained while running in a quarter mile and not for any length of time at all. Mainly on a drag run. Motor has ohio crank, and ohio i beam rods with arp 2000 rod bolts. Would it be wise to change the bolts to L-19 rod bolts? Compression is only 10-1.
572 with 6.535 in a 10.200 tall deck? Sounds to me son you got the wrong rods in this engine,because the math don't add up
It will work,but I'm not to accustomed to putting the pin that far down on the piston,my preference
I just believe it gets a better ring stack and better piston control with the pin hight closer to the top JMHO
Everyone does thing differently,I'd used the 6.7 rod or a custom aluminum
to get a better deck hight is all
